Scratched battery foil during removal
I scratched my phone battery foil as I was tryi6to remove. After fixing the phone and fixed back the battery, turn on the phone. The battery started draining fast. How do I fix the battery to hold char
@samken "How do I fix the battery to hold char" you do not. You replace it. It is absolutely possible that you have received a bad battery. Replace it once more from a different seller and re-evaluate. You also want to make sure that you have your power saving mode on, and your apps and network settings reflect those as well.
このアンサーは役に立ちましたか?
Ok thanks, I will have to replace it then with a new battery
@samken It's the safest thing to do. Best of luck.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 59
