メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年10月26日にリリースされた第4世代のSurface Proタブレット。
Touch Screen horizontal dead zone
Hello I have followed the I fixit instructions as well as others and replaced my faulty sp4 screen with a brand new LG sp5 screen (screen displays perfect) I have also replaced the LBoard (ntrig) with a new one. When I'm in Windows 10 I have a 2 inch horizontal dead zone about 1/4 of an inch down from the top of the screen. Neither finger or pen work in this area,
If I boot in uefi it demonstrates the same behaviour,
Note1: I have also fitted my original ntrig (Lboard) aswell and have the same problem.
Note2: I have run all diagnostic test in surface Diagnostics, done fresh restore on Windows,
Note3: I have not yet replaced the digitalizer cable.
Is it possible I have a defective screen or digitalizer cable?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
mrkeshin88 since this "2 inch horizontal dead zone about 1/4 of an inch down from the top of the screen" does not change, and it is consistent within and without your OS, it appears as if you have a failed digitizer. You would have to replace it and recheck
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
That's my thoughts, I have contacted the supplier as this is a brand new screen I have purchased and installed
さんによる
コメントを追加
I am experiencing the same issue; it appears to be a problem with the touch digitizer. Could you kindly provide any links where I can purchase a new digitizer for the Surface Pro 5th generation model?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
mrkeshin88 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 22
今までの合計 782
