メインコンテンツにスキップ
Repair guides and support for your Philips TV.
244回答 すべてを表示
Backlight on but no picture
Hi everyone I got Philips tv with no picture but with sound and backlight on.When I unplugged left or right ribon going from t-con bord to panel , left or right side of panel will work so I assume that panel is OK....Is that sign of bad t-con or main board?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@nicktree85 yes and no. Yes , your panel itself is okay, but (big but) your panel driver may not. A failed T-con board would not give you a picture on both sides. Of course, like anything else in life, things change. So, who know Philips may have something up their sleeve. Anyhow I would check the voltages on the T-Con board. Specifically, you want to find VGH on the T-cno board. Measure that with a multimeter in DC mode. Then you will have to go and find it and measure it on the driver boards. Those are the boards that are connected to the LCD panel via fine ribbon cables. The are not removable (by the DIY'er) Let us know what coltages you can find. It might also help if you post a few pictures of all of your boars with your question. That way we can try and assist you with that. iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Martin Bardiovsky さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 71
