メインコンテンツにスキップ
Lexmarkプリンターの修理ならびに解体ガイド
19回答 すべてを表示
Is my yellow toner at risk of leaking?
I had to replace my cyan and magenta toners for the same issue as can be seen here. I do not have a photo of the yellow toner but it's basically doing the same thing. I have a new yellow toner on hand but this one still has a bit of life left, the others were too close to not call it.
Is this leak worrisome to the point it's probably time to replace the yellow as well?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
選択されたソリューション
Ended up needing to replace yellow too :/. It got to that point as well.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
Laser toners do shed a bit of toner through use. I wouldn’t call it a leak exactly. I used to sometimes wear gloves because the cartridges were covered in powder. Depending on levels you’re probably better changing them as a set then hopefully they’ll all need replaced at the same time.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I'm changing them as I go, not as a set. The black is still fine
さんによる
My concern was the severity of it; I honestly expect a little bit, but this was bad. The waste toner on the cartridge was full.
さんによる
コメントを追加
回答を追加する
Nick さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 59
