After putting in new battery’s the keyboard still won’t turn on
I replaced the old battery’s and my keyboard still wont turn on
If replacing the batteries did not resolve the issue with your Logitech Slim Folio keyboard, here are some additional steps you can try:
If none of these steps resolve the issue, there may be a hardware problem with the keyboard. In that case, it may be necessary to contact Logitech customer support for further assistance or to arrange for a repair or replacement.
このアンサーは役に立ちましたか?
Both the battery change and the answer I found here were exceedingly helpful. I so appreciate clear instruction and being able to do this myself!
Sorry, the Slim Folio has no power switch. It has 2 CR2032 batteries. No way that I can see to "reset" it except to take batteries out and leave them out for a bit.
Same issue with Robert... No power switch. It's just a power button at the right top corner. Try to press and hold the power button for 5 to 10 seconds and it still doesn't work.
Seems to be a technobabble AI generated answer that is hallucinating about what it does not know.
Same problem here. Suddendly Slim Folio stopped working. Changed the batteries (yes, they are in correct orientation) but nothing happened.
I’ve got this problem. Light went out on batteries. Still blank with new batteries. I’ve checked everything multiple times and uninstalled from list of devices. No reset button and no fn key as some describe. Aaaagh.
このアンサーは役に立ちましたか?
過去 24時間: 11
過去 7 日: 60
過去 30 日: 221
今までの合計 11,470
3 件のコメント
Strange, Same thing happened in December for us - is there a date in some firmware ?
joschHh さんによる
Did anyone actually find a fix??
CNez さんによる
I have the same problem
Stanislava Kashtanova さんによる
