メインコンテンツにスキップ
Also sold under the GMC Sierra and VIA Vtrux names, available in the US, Canada, Mexico and other countries around the world.
80回答 すべてを表示
Why wont my truck start but will slowly crank after an engine swap
Did an engine swap and now it will crank slowly but wont start. What could be some issues. Already put in new battery and double checked grounds
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント:
Kristina McDonald whe you did your engine swab, did you swab the electronics from the donor vehicle as well?
さんによる
No. We put the same engine in as we pulled out. Do you have to swap out electronics too even if its the same
さんによる
@Kristina McDonald same year etc. or an engine that fits? A lot of times it does require the electronics as well. Check this answer by @automotive and see what you think. Truck starts for a sec then dies evertime
Yes, different model but same idea.
さんによる
コメントを追加
1 件の回答
Depending on model it could be out of time.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kristina McDonald さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 25
