メインコンテンツにスキップ
より早い処理スピードを可能にしたiPhone 3Gのアップグレード版です。このデバイスの修理は3Gと似ており、標準のドライバーと開口ツールが必要です。モデル番号 A1303 / 16 もしくは 32 GBの容量 / ブラックもしくはプラスチックの背面ケース
1500回答 すべてを表示
Screws are stripped on iPhone 3GS
So im trying to replace my battery on my iphone 3gs and im doing all the guide on here and stuff. but im on the part were u have to remove the screws on the board and the camera....but 2 of the screws are stripped and cant get them out. Anything i can do to get them out or am i *@%& outta luck and need a new phone?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
3件の回答
ベストアンサー
Have no fear frustrated user. No need to smash your old phone or tools. There's not even a need to buy a new phone!
So, you didn't mention which screws are stripped, but you have a few options for removal depending on accessibility of the screws.
1: Drill em out. Use a bit just a tiny bit wider than the screw body (use other screws as a judgement) and drill the head off. This method is typically high vibration and generally vary rough on your gear.
2: Slot the screws with a dremel cutting bit, then use a flat head to extract. Again the cutting can be rough on the phone and this option may not be plausible depending on screw location.
3: Screw extractor set. Much nicer on your equipment and may come in handy for future applications? May not work if you've completely rounded the heads out.
4: Screw extracting pliers. May not be usable if there isn't sufficient clearance around your targeted screws but is another gentler alternative to dremeling and drilling.
Any of these methods will work. Naturally the use of power tools requires extra caution to prevent collateral damage to the phone and yourself. Choose your weapon and good luck!
Precision Screw Extractor Setの画像
製品
$24.99
Screw Extracting Pliersの画像
製品
$19.99
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
this will not be a helpful answer by the way... but my iTouch (2 or 3generation) has the same problem i am stuck on 2 screws.. completely striped.... i cant get them out, the only tools i have are a philips screw driver and flat head and the other tools i ordered off of amazon... and i dont have a drill bit thing or any thing else anyone suggested... i cant get one... and i need help...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Phillip, do you know if heating the screw driver and thus threadlocker would make it easier?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
timmcmeekin さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 3,424
