メインコンテンツにスキップ
The Acer Spin 5 is a mid-range laptop with a 15.6-inch display. The Spin 5’s display can rotate nearly 360 degrees around the base of the computer, which makes it very versatile for various applications. Our research has not indicated any major recurring issues with this device or any manufacturer recalls since its release.
Why is my laptop on switching on?
my laptop went off whiles i was using it and never switch on
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Did you tried replacing the battery? It can be an issue with your laptops logic board or it can be a faulty connector or a battery. Try opening it up and checking on the battery connector’s condition or any corrosion on the motherboard.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Draphor knowledge kwame さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 117
