メインコンテンツにスキップ
The Kia Sportage is a compact crossover SUV (sport utility vehicle) manufactured by Kia Motors, a South Korean automaker, since 1993. Between 1993 and 2005, the Kia Sportage was classified as a compact SUV.
4回答 すべてを表示
I put in a new fuse and it blows it
Tail lights don't work I put in a new fuse and it blows it
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
@babydolly what exact year is your Sportage. remove the taillight bulbs and see if it still shortens out and blows the fuse. It does sound like a short in the lamp assembly but we need to see what else is on that circuit.
さんによる
Hi @babydolly,
Has the vehicle got a towbar?
If so. the vehicle then also has a socket connector for the brake/tail/turn indicator lights to be cable connected through to a box trailer/van etc.
Just another place to check for problems if a fuse blows for any of these lights.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Remove the tail lights and test for continuity with a multimeter between the bulb connections and a good ground on the chassis. If you have continuity between both pins and the chassis then there is a short on that circuit. Should only get continuity on one connector.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Victoria Bailey さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 4
今までの合計 36
