maytag laudry center washer is not working
do not start the washer
If your Maytag laundry center washer is not starting, there are several things you can check to try to troubleshoot the issue:
Note that these are just some general troubleshooting tips and the specific steps may vary depending on the model of your Maytag laundry center washer. It's always a good idea to consult the user manual or contact Maytag customer support for further assistance.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 58
Hi,
What is the model number of the combo unit?
Does the dryer work OK?
Have you checked that the power supply for the unit is OK. Usually it requires 240V i.e. 2 x 120V power supplies separately fused.
jayeff さんによる
