Is in Power Save Mode and keyboard not working
here are a few things you can try to troubleshoot the issue:
Note that the Dell OptiPlex 780 Small Form Factor was released in 2009, so it may not be compatible with the latest software and hardware. To get out of Power Save Mode on your Dell OptiPlex 780 Small Form Factor desktop computer, try the following steps:
If none of these steps work, it is possible that there is a hardware issue with your comp
このアンサーは役に立ちましたか?
Yes it is in power save mode
過去 24時間: 0
過去 7 日: 6
過去 30 日: 45
今までの合計 2,154
Hi,
Press and hold the Power button >5 seconds to force stop the PC and turn it off.
Then start it again in the normal way.
Was the keyboard working OK before?
jayeff さんによる
how can i fix kybord not found
Mulu Fami さんによる
