The oily, gummy fluid you are seeing on your GE Profile refrigerator could be due to a few different things. It's possible that the dispenser valve or tubing is deteriorating, which is causing the oily substance to leak out. Another possibility is that the refrigerant system is leaking and the oily substance is a refrigerant oil.
Either way, this is not a good sign and it's important to address it as soon as possible. Here are some steps you can take:
- Unplug the refrigerator: Before doing any repairs, make sure to unplug the refrigerator from the power source to avoid any electrical hazards.
- Check the dispenser valve and tubing: Inspect the dispenser valve and tubing for any signs of deterioration or damage. If you see any cracks or other damage, the valve or tubing may need to be replaced.
- Check the refrigerant system: If you suspect that the oily substance is refrigerant oil, you will need to have a professional technician come and check the refrigerant system for leaks. Refrigerant leaks can be harmful to your health and the environment, so it's important to have a qualified technician handle this.
- Clean up the oily substance: Use a clean cloth to wipe up any oily substance that has leaked out and dispose of it properly. Avoid using any harsh chemicals or cleaners, as these can damage the dispenser valve and tubing.
Overall, it's important to address any issues with your refrigerator as soon as possible to avoid further damage or potential safety hazards. If you're not comfortable making repairs yourself, it's always best to contact a professional technician for assistance.
2 件のコメント
Hi @tmhanser
What is the model number of the refrigerator?
Have you checked the condition of the water filter if there is one installed?
jayeff さんによる
GE Profile Model Number(s): PSHS6RGX/PSHF6RGX
With the help of a small mirror, I can see up behind the plastic actuator plate and I noticed a glob of amber-colored substance dripping down from behind a rubber seal. I'm sure this is where it's coming from.
The water filter was changed two months ago and it's tightened down. There is nothing leaking inside the refrigerator.
I have no doubt this refrigerator is past its prime. Having it repaired at this point might not be worth it.
Thanks, jayeff.
Thomas Hanser さんによる
