メインコンテンツにスキップ
Support for the third generation of Chrysler Town & Country spanning model years 1996-2000.
11回答 すべてを表示
No power to radio, windows, wipers
I have a 1999 dodge caravan sport and it just recently started to have a problem. When I crack the van up it sounds like a small pop sound under the dash and I have no power to the wipers, windows, and radio, and the air then switches to the defrost automatically. However, when I turn the van engine off the accessories then come back to life, but they go back out again when I start the motor.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I immediately suspect a bad ground. Most vehicles have a grounding block that will commonly ground many accessories. It will usually have a metal strap looking cable coming off of it that connected to the motor, trans or frame.
Hopefully someone here can tell you where to find the grounding straps on a 99 caravan. Unfortunately I have no idea.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Robert さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 3
今までの合計 78
