メインコンテンツにスキップ
Not showing up in finder
Hi everyone I just got an iPod shuffle 2 and it’s not showing up in finder does anyone know how to fix it
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
4 件のコメント:
Do you have a Windows computer?
さんによる
@andrewsawesome I'm struggling to work out what finder is.
さんによる
@thequacker I see, crapple stuff. I use Windows lol. ITunes, 3u tools but never heard of finder.
さんによる
コメントを追加
1 件の回答
If your iPod Shuffle 2 is not showing up in Finder, it may be due to a number of reasons. Here are a few things you can try to fix the issue:
  1. Check your connections: Make sure your iPod Shuffle 2 is properly connected to your computer using a USB cable. You may want to try using a different USB port or cable to see if that helps.
  2. Update your computer: Check to make sure your computer's operating system and iTunes software are up to date. If not, update them to the latest version.
  3. Restart your computer: Sometimes restarting your computer can help fix connection issues.
  4. Reset your iPod Shuffle 2: Try resetting your iPod Shuffle 2 by toggling the on/off switch on the back of the device to off and then back on. If that doesn't work, try restoring your iPod Shuffle 2 to its factory settings using iTunes.
  5. Contact Apple support: If none of the above solutions work, you may want to contact Apple support for further assistance.
I hope one of these solutions helps you fix the issue and get your iPod Shuffle 2 connected to Finder.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sami さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 15
過去 30 日: 71
今までの合計 2,385
