メインコンテンツにスキップ
Released August 2018, identified by model number ‎A3902J21.
1回答 すべてを表示
Dropped them into the toilet... Left earbud now quiet
Hi!
I made a mistake, the earbuds + case fell out of my pocket and into the toilet... I immediately heated them with a hair dryer for about 10 minutes, sprayed contact cleaner and cleaned with isopropyl alcohol, although I haven't taken them apart yet.
I let them dry, everything seems to work but the left earbud is really quiet.
Is it fixable?
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi
It could be a bad battery in the earbud but I suspect that by heating them with a hair drier that may have slightly melted or deformed the driver/speaker
It might be worth waiting a day or so to let them dry if you don’t want/can’t open them
Hopefully this helps
Any questions please ask
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
I have opened them up, cleaned the back of it with iso, and now they are working! Is it worth me opening up the other end of the earbud, plus the other earbud to check for damage or do you think it will be ok?
Thank you!
さんによる
@yotoprules
I would do the same yes
As long as your comfortable doing so
Better to be safe :-)
さんによる
コメントを追加
回答を追加する
yotoprules さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 321
