メインコンテンツにスキップ
モデル番号A1137/1、2、4GB容量/カラーオプションはブラックとホワイト
How to clean out the mess the battery made?
So I think this was the faulty battery that never got replaced by apples fault.
It still turns on but the battery is degraded.
How should I clean this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi @beanman56,
I would start with a clean, lint free cloth moistened (not dripping) with IPA99%+ and try to wipe away any corrosion etc.
Wipe over any spot once and then select a clean area of the cloth and wipe over the same area again. Keep repeating with a clean section of the cloth each time until it is as clean as you can get it.
Always wiping only the once with a clean moistened section of the cloth means that you won't be spreading any corrosive particles to other areas.
If a cloth is too big or awkward then try a Q-Tip but again only wipe the one time, each time. May take a fair number of Q-Tips though ;-)
Takes a while but in the end it's worth it.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Ben Capehart さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 87
