メインコンテンツにスキップ
初代モデルのiPhoneです。モデル番号はA1203で容量は4, 8,もしくは16 GBから選べます。アルミニウム製の背面ケースです。開口にはかなりのこじ開けるための力が必要です。そして半田付けも若干必要です。
Help! iPhone stuck in boot loop with weird shadowing on screen
im planning on replacing the display, just need to find a part with a digitizer and lcd with all the small parts
it only turns on when its plugged in as shown in the video, and has a weird shadowy affect after it turns itself off.
anyone know what to do?
ive tried putting in in dfu mode while its doing this,hard resetting also, and it doesn't help
is this also a display issue/recovery issue or is it something else?
I GOT TO GO INTO RECOVERY MODEEEEE
okay but is it compatible with the newest itunes update?
what do i need to do to actually recover this phone?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
are you concerned about data on the phone?
if not, then i'd recommend downloading 3utools and installing it on your PC. put the phone into DFU mode (you will need to google how to do this for your model), connect it to your PC and execute a anti-recovery Flash.
this will install the latest firmware and IOS for your phone.
this usually works for me when i get bootlooping phones to evaluate - but only if the data is expendable.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
@beekerc
is there a version for mac?
also i don't mind the data, i bought this phone off ebay to repair
さんによる
also the phone turns off before i can put in dfu i only can barely get recovery mode to work in time before it shuts off it only stays on for about 10 seconds before turning off:(
さんによる
@timtomissus
no. 3utools is for pc only, sorry
さんによる
コメントを追加
回答を追加する
timtom77 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 268
