メインコンテンツにスキップ
Car lineup featuring sportback and sedan models.
7回答 すべてを表示
Why won’t my reverse lights work?
My reverse lights won’t work
Iv brought it to mechanics and they have checked everything
Is there anything else they could be missing or is there any well known problems with head lights in Audis
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Hi Kayleigh,
What year is your A3? Is there any relevant submodel information that would help us look up a wiring diagram for your car so we can see if we can help? Is it an automatic or a manual transmission?
さんによる
Hi @kayleighcliff22
Reversing lights or headlights, as you mentioned both?
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Mechanics are not the place to take it when you have an electrical issue. You need to take it to an auto electrician to diagnose properly. Yes, they charge more per hour, but they will fix the problem. Yes, there was a common problem with dry joints and relays requiring cleaning inside the Body Control Modules, but will need you to confirm Model, engine size and Year to see if it relates to your vehicle.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Kayleigh さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 18
今までの合計 111
