メインコンテンツにスキップ
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
170回答 すべてを表示
"Whea uncorrectable error" blue screen
Hello, I changed the processor of my pc and I also put a new graphics card in it, and when i play any game (Fifa 23, Valorant, Tomb Raider, Fall Guys, etc) it crashes and restarts itself or the error "whea uncorrectable error" appears.
I tried formatting the pc from 0, downloading the latest version of drivers and bios, verifying that everything is well connected, etc.  I also tried changing the power cable of the power supply, and it keeps happening.
Then, I changed the processor to the old one, leaving the graphics card, and it worked fine, but when I reinstalled the new one, the error appeared again.
Can someone help me?
PC specs:
Ryzen 5 5600 (the previous one was a ryzen 5 3400g) - MSI Rtx 3050 gaming x - 2 x 8 gb 3200mhz - B450m ds3h gigabyte - power supply of 650w 80+ bronze - SSD 240gb - HDD 500gb
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Two things spring to mind. And maybe you've done this already, but have you tried clearing the CMOS between the two CPUs? I would even go so far as to remove the little button cell battery rather than just using the jumpers.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
no, I didn't do that, but I took the pc to a computer technician and he told me that he didn't get the error and it worked fine. Later, I tried it in another house and it worked fine. I don't think it's a computer problem. What should I buy to fix it? I also tried with voltage stabilizer and it didn't work.
さんによる
コメントを追加
回答を追加する
Felipe García Kralj さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 266
