メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Why is Panasonic 2012 TV turning off, standby light blinking 12 times?
My Panasonic TX-P42GT50b will turn off almost immediately after being turned on and then the standby light will proceed to flash 12 times. What problem could be causing this and how can I fix it?
画像
画像
画像
画像
画像
Close ups of A Board:
画像
画像
画像
画像
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
Can you take the back off the TV and upload pictures of the circuit boards? iFixitでの質問に画像を追加する方法
さんによる 共有
@andrewsawesome I've added pictures, let me know if you need better pictures of something in particular. I don't really understand where the problem could be. Thanks :)
さんによる 共有
コメントを追加
1 件の回答
最も参考になった回答
@iambelen 12 blink error code on yourTV model is showing as a Sound SOS. Caused by either a bad A-board or the speakers (including woofer). Try to disconnect the speakers and see if that changes anything.
画像
Update (02/17/2023)
@iambelen yes. the complete board where the sheetmetal is bolted to, is the A-board. That is where the Audio Amplifier circuit sits. as well where the feedback for the 12 Blink code originates from. The connector A12 on that board should be for the speaker cables.
画像
このアンサーは役に立ちましたか?
スコア 1
13 件のコメント:
@oldturkey03 might be a dumb question on my part, but where are the speakers? and is the a-board that entire section or just the metallic bit that you're pointing to?
Thanks btw
さんによる 共有
@iambelen post a close up picture of that conector with your question. Go to edit to add it.
さんによる 共有
@oldturkey03 I tried disconnecting A12 and then turning the tv back on and nothing changed. Is there anything else I should try?
さんによる 共有
@iambelen okay so no change with the speakers disconnected. Can you get a couple of close up of that particular "A-Board"? LEt's see if we can find something obvious. After that the only thing to do would be to change the board. I would dislike for you to have to spend money unnecessarily.
さんによる 共有
@oldturkey03 I added the close-ups of the a-board to the main question
さんによる 共有
8件以上のコメントを表示
コメントを追加
回答を追加する
Belen さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 39
今までの合計 1,002
