メインコンテンツにスキップ
The DJI Mini 2 is a small drone that was made in 2020 by DJI. The DJI Mini 2 has 4K/30fps video and 10km 720p/30fps video transmission.
12回答 すべてを表示
ESC error after only 58 minutes of flight.
I had flown my mini 2 for 58 mins in total. And left it for a month, when I came back from my travels. I had neatly packed it in its bag inside my closet.
I turned on the mini 2 and it gave me an error ESC. Nothing worked, no updates, it clocks out at 80%, no company help, as I bought it in the USA, but live in Europe.
I'm stuck, it's an $800 brick now. Can you help fix it, I'm super girlie and have none of the gadgets on the fixit page!!! Don't know what to do!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Can you download DJI Assistant 2 for Mavic and try and update the drone and controller firmware using this guide? You must do it on a computer running Windows or MacOS Mojave or earlier.
このアンサーは役に立ちましたか?
スコア 2
7 件のコメント:
@thequacker Assitant software doesn't see the plugged-in drone
さんによる
@l_j What OS are you using? And have you tried a few different cables? If you have the one that came with the drone try and use it.
さんによる
Tried 4 cables, and three different batteries. With and without an SD card.
iOS 16.3 for my iPhone, and drone firmware 01.04.0000 and will not update at all. Gets to 80% and errors (for the last 8 months now).
Also, Drone does not show up on drone assistant 2. The RC does however and updates normally.
さんによる
@l_j What OS is the computer with DJI Assistant on? Windows 10/11, macOS Ventura, etc?
さんによる
@thequacker ventura
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
Layal Jebran さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 14
今までの合計 239
