メインコンテンツにスキップ
Repair information for KitchenAid dishwashers.
19回答 すべてを表示
kdte334gps0 buttons won’t work powered up
Hello our kdte334gps0 KitchenAid dishwasher is 5-6 years old worked fine until today. The buttons won’t respond to touch. Every 1-10 mins, it will beep once and the ProWash and Extended Dry LEDs will light up for about 30 seconds and then turn off.
Power cycled, Checked all connections, no wires look broken.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @kshepherd
Here's the tech sheet for the dishwasher.
Try to run the diagnostic tests as seen on p.12 and check if any error codes are shown. The error code info is from p.14→
このアンサーは役に立ちましたか?
スコア 1
13 件のコメント:
Thanks for the reply @jayeff ! I wish I could but I can’t even hit the buttons to enter the diagnostic mode. None of the buttons respond when I hit them. I even tried the combo a few different times just in case and it won’t work lol !
さんによる
@kshepherd
Check that the control panel cable is securely connected to the control board. Maybe disconnect the cable and check that the cable ends aren't corroded etc
Could be a faulty panel (stuck key?) or the control board (sticking relay?).
Maybe check if there's 13V on the door latch switch (see Door switch strip circuit p.5) just to check if the control board has the correct voltage to operate
If the control panel is faulty the part # is W11165145 search for suppliers that suit you best. The control board is W11120155
さんによる
Thanks Jay! Everything seems connected - and the door switch is showing 12.45V so seems like it’s within range lol. Any other ideas? :)
さんによる
@kshepherd
I don't know.
I'm thinking that it's a control panel problem as the keys seem unresponsive, but I'm no expert.
See if you can source a replacement from a supplier that accepts returns either with a full refund or a minimal restocking fee so as to reduce the cost to you if it isn't the problem
さんによる
@jayeff you have already gone above and beyond here but I was hoping you may give me a bit more advice. I tried reading the service manual on how to do it, but do you see any way of testing whether touching the buttons is being received by the controller? In other words, where I can put the leads on my multimeter and then hit any of the buttons? Or is that a waste of time at this point?
さんによる
8件以上のコメントを表示
コメントを追加
回答を追加する
Kyle Shepherd さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 19
過去 30 日: 70
今までの合計 522
