Hyundai accent 2019 ... why does the ABS alarm lights after a rainy da
Hyundai accent 2019 ... why does the ABS alarm lights after a rainy day?
ahmedhadiabbas1968 it is possible that one of the sensor wires got shorted out. You want to check those sensors/wires for corrosion as well. There is also a possibility, that the rain water carried enough debris with it that there is muck and debris on the sensor. Cleaning it should help. Ultimately, I suggest that you get the OBD on your Hyundai scanned and see what codes pop up. Anything else will really just be a guess.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 37
