メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPadの第3世代モデルで4G対応。2012年3月16日に発売。モデル番号はA1430。修理には熱を慎重なこじ開け作業が必須です。
Ipad 3 distorted crackling static noise when trying to play ANY sound.
Ok so I got an Ipad 3 3g (A1430) for repair I changed the battery and the speaker because it wouldn't make any noise when trying youtube or notification sounds, I was testing all new components, the battery its ok but the speaker would only play static while trying any type of sound, I recorded how it sounds and have the video here: https://www.youtube.com/shorts/2fLYcFgrG...
I already returned the new speaker but I'm wondering if it was a bad replacement or is it something else on the logic board.
Thank you!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Visually inspect the socket on the logic board and look for discoloration or bends on any of the pins. From your description, the speaker is receiving power properly, so the problem is improper data transfer at either a pin on the connector, or in the speaker wire itself. A new speaker will certainly confirm the issue. A new logic board is always an option, but may cause home button pairing issues.
Replace a logic board compatible with the 3rd generation 4G iPad tablet. Fix processing issues like unexpected shutdowns, reboots or water damage.の画像
製品
iPad 3 4G Logic Board
$31.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
PsiBot さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 283
