メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
old water damaged iPhone with power issues - anyway to recover data?
i have an iphone 5s that overheated in 2019 and died completely, which was later submerged in water for about half a day and smashed (stupidly), is there any chance whatsoever of recovering the data off the board? the phone in a new housing, battery, display, etc just warms the battery like it did before it was water damaged, is it a lost cause?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
probably not. once the phone innards get wet, your worst enemy is time. the quicker you can get it dried, the better. the longer the liquid sits, especially in a closed phone, the greater the damage from corrosion.
here's what i recommend. get the motherboard out and give it a good 1+ day soak in 99%+ isopropyl alcohol (IPA). if you see any visible residue or corrosion, give it a very gentle scrub with a very soft tooth brush (like the kind dentists give free to young kids). after the scrub, give it another soak (at least half a day this time) in clean IPA. agitate a little then take it out and give it one final rinse with clean IPA. bend a paperclip open and pop one end through an open hole so you can hang it to dry in a slightly (or much) warmer room than usual room temperature. make sure the humidity is as low or lower than normal (ie, using a hot shower to raise the air temperature of the bathroom would defeat the purpose - i know this should be obvious, but sometimes ya just gotta say it). let it air dry for at least a day or two.
at this point, if you have known working and dry parts, you can reassemble and give it a shot. i'd be hesitant to use the original parts because of both the liquid and physical damage.
at this point it's a crap shoot. if the board is dead, no amount of IPA will resurrect it. but i have used this method to bring motherboards back to life than had suffered major liquid damage.
good luck to you
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
yeah, thanks for confirming what i had feared. oh well, i will now backup my phone and be more careful next time
さんによる
コメントを追加
回答を追加する
bit さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 4
今までの合計 35
