メインコンテンツにスキップ
Google Pixel 2は2017年10月17日に発売されたgoogleの第二世代モデルです。このスマートフォンは5インチAMOLEDディスプレイと64もしくは128GBの容量オプションがあります。3色のカラーバリエーションがあり、Just Black、Clearly WhiteもしくはKinda Blueから選べます。
70回答 すべてを表示
Slipped and damaged a golden contact point with screwdriver :-(
Hello all!
Since my last post had received some very helpful and kind answers, I have another question to ask. A while back I was replacing the back glass on my pixel 2.... and slipped with the screwdriver. I hit the motherboard from behind and as a result caused a dent at the speaker contact point. Now all the top speaker does is make a crackling sound that never ends.
I have attached a pic. The bottom golden point that was obviously damaged got hit from behind. Is there a way to fix this without resorting to microsoldering? On the second pic, the speaker and its two golden contact points are visible. If I use a piece of tape to block the bottom pin from connecting to the dented point, the speaker doesnt engage at all unfortunately. It may need both connected to work. When I sticked a piece of copper tape on it, the audio started to falter intermittently.
Thanks!!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Hi Gaul,
It's a little hard to be sure from your pictures, but it appears the circuit trace going to that pad where the speaker contacts it has been damaged. The best way to fix it is to solder a jumper wire from that pad to another point past the break; that will give you a good, continuous connection for current flow. I poked around looking for schematics and/or Gerber (boardview) files, but didn't have any luck; having those would make the job considerably easier.
Anyway, it looks as though there might be test points nearby; it's conceivable that one of them is connected to that pad; if so, that's a major step in the right direction. What you'll have to do is figure out an exposed point that you can take some thin wire, say 22 AWG, and solder it onto that pad, then run it to another point within that same circuit. If you look carefully you'll see the copper circuit board traces are there and covered by black stuff called solder mask; the traces are under that, but insulated so they don't make contact with anything other than what they're supposed to touch.
If you can visually follow the path of that trace, you'll hopefully come to some point on the other side of the break where there's metal exposed, whether that's a test point (the gold circles) or a component doesn't matter. That's the place to solder the other end of the jumper wire to.
If you can't make it out by looking at it, the next thing to try would be to use an ohmmeter or continuity tester to try and find a contact point. This might be more difficult due to the break; the contact may be intermittent depending on the break and whether it's flexed in a position where it's open or it's making contact. I'd try probing a couple of points and pressing on the break to see if you get a beep indicating continuity.
I've marked a couple of places that look like likely candidates to check; don't limit yourself to those, but they're worth checking. The red arrow is pointing to the speaker pad where you'll put one end of the jumper wire, and the orange arrows are test points that are worth checking. Also check the components around that area; there are several resistors and capacitors nearby that could be connected to the pad.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Jerry, once again your help came through clutch, I dont really understand the fine details about any of this but you really make it digestable for someone who isnt an expert. Sounds like I have a plan now. I do not have much soldering experience but it seems like it's time to get some. Even if it doesn't work out, it will be worth the shot. Your help has been very much appreciated!! Have a nice weekend.
さんによる
コメントを追加
Hi
Assuming that the dent hasn’t damaged layers of the board a little solder on the pad that’s damaged might help the issue ,you could also use silver conductive paint,just make sure not to let it touch other pads or components
As I said this is assuming that the layers of the board aren’t damaged below the surface
Hopefully this help
Any questions please ask
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Also remove the blue tissue looking stuff at the top
さんによる
コメントを追加
回答を追加する
Gaul Soodman さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 12
今までの合計 118
