メインコンテンツにスキップ
サムスンの主力スマートフォンでNote 8の後継モデル。2018年8月発売。6.4インチのディスプレイと最大512GBのオンボードストレージを搭載。
104回答 すべてを表示
My Note9 says no network conct, yet connected and not thru wifi
Can't call or text , says no network connection but I can do anything online and not using wifi, my icons on top rt show data connect with arrows but signal bars have x thru them wifi is not turned on i have talked with network tech and gone thru trouble shooting too many times got new sim and problem happened again, I am having to use a wifi calling app so I can make phone calls outside of Mesgr.
Any help would be greatly appreciated thank you
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Does it work if you try your sim card in another phone? Could the phone be network locked? Have you tried it with another SIM card?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Woah this is the second sim card it did something similar to this but I had no connectivity what so ever the first time, wait now that I think about it all this started when I got a text to get a new sim to get on 5g and when I got the new sim I first could not make calls or text tech fixed that but I could not send pic msgs got a new sim and it worked ok still could not send pic msgs then all of a sudden I can't call or text so idk what the problem is, we, me and tech support, came to conclusion that it was a ack that sent the message about 5g sim but idk why this problem happened again after new sim
さんによる
I have not tried it in another device bc if the sim is bad I don't want to mess up anyone else things still not sure what the problem.
さんによる
コメントを追加
回答を追加する
Nancy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 7
今までの合計 41
