メインコンテンツにスキップ
Appleの主要モデルである2021年のiPhoneは、9月24日に発売され、6.1インチの有機ELディスプレイ、デュアル12MPカメラシステムを搭載し、5色のカラーバリエーションが用意されています。iPhone 12の後継モデルです。
96回答 すべてを表示
I can’t hear phone calls unless iPhone is on speakerphone how to fix?
iphone13 can only hear phone calls on speaker or other audio device. I have run through a lot of suggestions online. Going to reset to factory defaults. I’m concerned it is a hardware issue. How do I trouble shoot solutions before taking it to shop or opening phone up?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
I would have a look at the iPhone No Sound troubleshooting page. But chances are there is an issue with the receiver speaker (earpiece speaker).
I would see if you can isolate which functions work properly. Try and play some media and set the balance entirely to one side or the other and see if that effects the sounds. That speaker will also function as an amplified speaker for playing media in stereo. It may just be the speaker grills are all gunked up.
The receiver speaker (or top speaker as Apple calls it) on these is no longer attached to the display, and if I recall correctly it takes some doing to get at if that turns out to be the issue. I believe the logic board has to come out to remove it.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Joseph Lopez さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 57
過去 30 日: 178
今までの合計 5,376
