メインコンテンツにスキップ
Appleの最も大型で高額な2019年モデルが9月20日に発売されました。6.5" OLEDディスプレイ、トリプルレンズカメラシステムと、大きく改良されたバッテリーライフが特長です。iPhone XS Maxの継続モデルです。
165回答 すべてを表示
11 pro max screen display glitching and distorted and restarts
My iphone is randomly have screen glitch and distorted and then restarts once in 2 weeks ive got a panic log but i cant analyze it. It says ''''"panicString": "panic (cpu 1 caller Oxfffffff02a175744): |"Timing out on commit.
Waited 5 s. KSWMPR INTERRUPT AP:0x0!"
@AppleSynopsysMIPIDS|Controller.cp:842\nDebugger message: panicinMemory
ID: 0x6\nOS release type: User\nOS version: 20D47\nKernel version: Darwin Kernel
Version 22.3.0: Wed Jan 4 21:25:00 PST 2023; root:xnu-8792.82.2~1V
RELEASE_ARM64_T8030\nFileset Kernelcache UUID:
F71BE3007A3C1018B7F4B740A55B91F7\nKernel UUID: BC87557C-955F-30F3-
B098-A51038EA70FB\Boot session UUID: D088F9BE-8A21-4E02-
BB46-103E7C8642AE\niBoot version: iBoot-8419.82.1\nsecure boot?: YES\nroots installed: O\Paniclog version: 14\nKernelCache slide:
0x0000000020db0000\nKernelCache base: Oxfffffff027db4000\nKernel slide:
0x0000000021a34000\Kernel text base: Oxfffffff028a38000\Kernel text exec slide: 0x0000000021af0000\nKernel text exec base: "panicString": "panic (cpu 1 caller Oxfffffff02a175744): |"Timing out on commit.
Update (02/06/2023):
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
I believe this is related to the display itself. The panic makes reference to AppleSynopsysMIPIDS. This would lead me to a Synopsis chip which makes use of MIPI type communications and the DS would likely refer to Display Serial Interface, a subset of the MIPI standard interface. I believe that chip is on the display.
If not, the actual display, it's something on the board end with either the display connector or communications between the display and the CPU. But I would wager display first.
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
TL;DR: Screen's probably shot, try replacing it. If that doesn't work, there's something wrong on the logic board, which will be a difficult repair, not something us DIY-ers are equipped to tackle.
さんによる
@dadibrokeit Yes. That exactly.
さんによる
So its a high chance that it is the screening problem? Because after ut restarts it is okay again, but after 2 weeks the issue keeps coming back
さんによる
@Kristian Vincent Mabalot Yeah, as Alisha explained, the phone appears to be losing communication with a chip on the screen. It seems to be very intermittent; if the error was there continuously you'd see a reboot every three minutes.
There are some cases where a kernel panic is caused by a software error; when that happens a full restore of the phone usually clears it up. Your case seems to fall somewhere in between the two ranges, as it doesn't explicitly call out a particular sensor, but the error is originating in a hardware communication bus.
Before going to the trouble and expense of replacing the screen, it would be worth your while to back up your phone, do a full restore and see if the error returns. If it's still there then it's almost certainly a hardware error, which could be caused by any of the issues Alisha mentioned previously. Basically, the only feasible fix is replacing the screen because if that's not the problem then it's in the motherboard, which is a whole lot harder to fix.
さんによる
Kristian, From the image, I’d say you’ll probably need a replacement screen. Make sure it’s a good quality one (I prefer iFixit screens). It could still be something else, as Alisha explained, but replacing the screen is the first thing I would do!
さんによる
コメントを追加
It happen again today, and im able to take a picture of it before restarting is it a display issue?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Kristian, I went ahead and updated your question with the image (from your comment a couple of minutes ago). iFixit doesn’t allow pictures in the comments, and it’s much better to update your question with new information, as posting it as “answers” can flood and distort the question :)
さんによる
コメントを追加
回答を追加する
Kristian Vincent Mabalot さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 48
今までの合計 695
