When I press the start button fan are working but no display output
When I press the start button fan are working but no display out put
Hi @pmkasun,
Have you tried a connecting a different, known working monitor just to prove that the monitor (monitor cable?) is not the problem?
If so try a power refresh in case it is a corrupted BIOS that is preventing a normal start.
If it works OK there may be a message saying that the date and time are incorrect. This is normal as the BIOS has been reset back to its factory default state. Once the d&t have been corrected the message won't appear the next time the PC is started. Also if any user definable settings in BIOS have been altered by you, to suit whatever operating requirement you have, they will have to be changed back to what they were as they have also been reset.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 7
過去 30 日: 44
今までの合計 338
