メインコンテンツにスキップ
iPhoneの第2世代モデル。モデル番号はA1241 / 8 もしくは16 GBの容量/ ブラックもしくはホワイトのプラスチック製背面ケース。修理はオリジナルiPhoneに比べて直接パーツに作業ができます。ドライバー、こじ開けるためのツールと吸盤カップが必要です。
1158回答 すべてを表示
締切られた回答
Sim tray will not go in all the way
My wife's iPhone 3G sim tray will not go in all the way and I do not want to force it and break the internals of the device. How should I repair this issue?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Are u sure you are inserting the sim card correctly? did u try to insert on both sides?
さんによる
I was putting it in the right way but it was pressing against the display somehow. Anyhow, I actually fixed this problem by opening up the glass cover and sliding in the sim tray while the cover was open. I then simply shut the cover and it worked fine. Thanks for your comment.
さんによる
コメントを追加
7件の回答
ベストアンサー
The SIM card goes in with the 3G label faces same way as screen and the notch is at top left. The exposed gold fingers face the back. When putting it back in it has some slop so just wiggle it going down to the seat.
I opened mine up to check it out. Good luck
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
research. I like research +
さんによる
コメントを追加
I think the tray is plastic so you could superglue it back together being sure to keep the sim card away until it is dry. Use a nail file to fix any high spots. Then put it back together.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My 1st gen iPhone has thus same problem, and I can't solve it. The sim card tray won't go in all the way. Any other suggestions? I'd rather not have to try opening the iPhone.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
if you buy one of those multi-purpose-duster things that have air in it and just try to clean out the inside where the tray goes in, that should help. it also works for audio-connection if you have problems with your sound. i went to the at&t store but they were no help. people say all you can do is get it checked out and then they might tell you to buy a new one, but for me, this helped and now it works fine.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
try tightening the screw on the sim eject lever. It helped me.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
how do u open the glass cover
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Had the same problem. Like Alex I had to adjust the screw on the sim eject lever; but found that loosening it slightly seemed to help. However, to get to the screw you have to partially disassemble the phone. Not for the feint of heart,
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 24,822
