メインコンテンツにスキップ
ロジクールのワイヤレスマウス「MX Master 3」の修理・分解情報です。2019年にリリースされ、モデル番号MR0077、910-005692、または910-005620もしくは910-005647で識別されます。
Not working but green light is blinking
My Mx Master 3 mouse just run out of battery. I am trying to charge it, but it seems that there is an issue with the charging of the mouse. when I plug it in the charger, no lights blink (as usual), when I plug it out, it starts blinking green but in a strange pattern. Not the charging pattern, nor the low battery pattern.
Regardless of the green blinking light, I cannot access any of the devices from the bottom of the mouse and it seems to not connect to anything. My mac is saying that the mouse is at 5% but cannot connect to it like normal.
Open to suggestions
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
7 件のコメント
Going through the exact same thing! Any fix?
さんによる
@theopyrillos @dvvvvv Could you guys describe the pattern? I have the MX Master 3 right here, but never experienced issues. Have you tried updating the firmware?
さんによる
let's say that when you charge it, you get a "breathing" light, that kind of smooths in and out. whereas in my situation is more of a pulsing light. unfortunately I cannot get it connected to anything to update and/or reset.
Spoke with Logitech Support and do not know about the issue. Their suggestion is to forget about getting it repaired.
I tried
- Leaving it to drain the battery and then recharge
- Fully charging it over night
- Installing Logi Options+
- Reset method from Logitech
nothing works.
The buttons do not respond to any action. The only action it responds to is on and off.
さんによる
i just sprayed some isopropyl alcohol on the power button switched it on n off then the lights turned on the 123 button. working fine now . mine started acting up after i charged it wouldnt turn on . till i sprayed it. good luck hope this help you out
さんによる
I have exactly the same issue... :(
さんによる
2件以上のコメントを表示
コメントを追加
5件の回答
最も参考になった回答
Ok Fixed it now it can even connect to Bluetooth no problem.
I followed the instruction in this site how to open mouse disconnected battery for 10 minutes then reattached battery and it works again.
remove feet carefully and slowly and you can reattach no problem also one screw is a star type lucky I had the screwdriver. good luck
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
As a rechargeable mouse, batteries have a finite life. It may be the end of life of the battery. Reviewing the right sidebar will reveal procedures for disassembly and replacing the battery. This presumes the mouse wasn't damaged from liquids, dropped onto a hard floor or other ways to damage electronics within the mouse.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Well I Will suggest you to check out the following video: https://www.youtube.com/watch?v=PfQ69PCc...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It's not the battery because the it was 100% before this problem appeared
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I just had the exact same problem: green light was blinking and so did a white device 1 indicator at the bottom of the mouse. Resolved it by turning the bluetooth on my mac off and on again. Hope this helps
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Theodoros Pyrillos さん、ありがとうございました!
統計データ:
過去 24時間: 8
過去 7 日: 73
過去 30 日: 343
今までの合計 13,078
