How to fix and or replace the sneers
the cushions are falling out and I need to know how to replace them or fix them
Hi Nix,
I have the qc35 ( i not ii) but I think it's similar enough. The cushions are held in by a ridge inside the headphones. Each cushion has a hard plastic ring ( oval shaped) that snaps into that ridge, all the way around the headphone. You have to push it in so it stays. If the cushions won't stay, I bought replacements on eBay and they worked perfectly well. Bose probably sells them too.
このアンサーは役に立ちましたか?
Some pictures to help see how the cushions fit.
The hard plastic on the cushion slide under the plastic tab on the QC.
このアンサーは役に立ちましたか?
It's not so easy, but not so hard either: https://www.youtube.com/watch?v=sA63FWBe...
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 23
今までの合計 478
