メインコンテンツにスキップ
CDMA iPad 2モデルの第二世代は16、32、64GBのオプションがあり、Dual Core A5プロセッサが搭載されています。モデル番号はA1397です。修理は細かい作業が含まれ、熱で温めてこじ開ける作業が必須です。
How to activate icloud
What must I do so I can unlock my iclod
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Hi Gabriel,
Sorry to say this issue comes up a lot with Apple products. Unfortunately there is currently no way for anyone other than Apple to remove an iCloud lock from any Apple device.
Your best bet is to contact the person whose account the iPad is locked to and ask them to remove the iPad from their iCloud account. If it's your own account and you've lost the login information, you can take the iPad to Apple and they'll remove the iCloud lock but you have to have the original proof of ownership.
If you bought the iPad from someone who sold it as being able to be activated, then you need to return it and get your money back.
Sorry I don't have better news for you, but that's just the way it is with Apple products.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Cant he use a Apple Laptop?
さんによる
@nytryder26 To do what, Ben? You may be able to connect it and restore the software, but the iCloud lock will remain.
さんによる
@nytryder26 As @dadibrokeit says; He may be able to connect to it, and perform a restore/update. The problem is that the iCloud lock is tied to the logic board, which is checked against Apples servers upon setting it up. The only two ways of removing it, is already listed
さんによる
@geirandersen Ok, Thanks for explaining this!
さんによる
コメントを追加
回答を追加する
Gabriel さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 191
