The GeForce GT 730 was a graphics card by NVIDIA, launched on June 18th, 2014. Built on the 28 nm process, and based on the GK208B graphics processor, in its GK208-302-B1 variant, the card supports DirectX 12. Even though it supports DirectX 12, the feature level is only 11_0.
@Nina Titi can you check the fan by just applying voltages to it? Do you have a small power supply that you can use for that? Make sure you apply the proper voltage of course. That way you can rule out the fan as the cause.
Nina Titi what fan? The one on your PNY GeForce GT 730 graphics card? What have you checked?
oldturkey03 さんによる
I am not quite sure on this model but the fan should not spin until it reaches a required temperature.
Chris Stables さんによる
@imicrosoldering But it never rotates even if the temperature rises greatly, and it does not rotate even though it receives electricity
Nina Titi さんによる
@oldturkey03 Yes, it does not rotate. I checked its access to electricity and cables, and it rotates heavily once and stops
Nina Titi さんによる
oldturkey03 さんによる
