when I turn it on the small lights light up but the screen is black?
those lights blink 3 times then stop blinking the battery light is red
Hi,
Disconnect the charger if connected and then remove the battery from the laptop and then plug in the charger to the laptop and check if it turns on OK
Here's the hardware maintenance manual for the laptop. Go to p.35 to view the procedure to remove the battery pack.
If it turns on OK then the battery is faulty and needs to be replaced.
Search online for 121500171 to find suppliers that suit you best.
このアンサーは役に立ちましたか?
it doesnt work there is no light the blinkers dont even light up
@masresha geremew
Check that there is 20V DC at the output plug of the charger.
If the charger isn't supplying enough voltage it can't charge the battery or turn on the laptop.
If the charger's output is OK then it looks like it needs a battery inserted to power on. Was worth a try as a lot of laptops will work without the battery inserted when the charger is connected..
The laptop will need to be opened and tested further as to what the problem is
Everything about
the charger is fine so wht should i do
@masresha geremew
You would need to use the schematics for the motherboard and start checking the power supplies on the motherboard.
if you can't read schematics contact a reputable, professional laptop repair service and ask for a quote to repair the laptop.
oh wait it just turned white should i come back and ask u if the pc turns on ill let it charge for an hour
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 72
Hi,
Have you tried charging the battery?
jayeff さんによる
thats the thing it was red for a long time but one time it lit up said something error choose something then before i read it quickly shut down
masresha geremew さんによる
