Why is my battery draining so fast (only 3 hours playtime)
I used it for almost a year now and the battery time keep getting lower and lower. Is it because of low battery health or hardware problem
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@helodi9250, The batteries in these units are very small, and if you use them a lot you will see degradation over a year.
Lithium-Ion batteries are good batteries, but when they start to degrade they need to be replaced (if possible).
There is no guide for that device replacement on here, so if you decide to go that route be sure to take some good quality pictures and take ample notes during disassembly. Then you create a new guide here, so others may benefit from your experience :)
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 2
過去 30 日: 11
今までの合計 103
