メインコンテンツにスキップ
Windows 8 touchscreen-compatible version of the Zenbook Prime UX31A
9回答 すべてを表示
possible ways for upgrading the RAM.
Where can I find the compatible motherboards for ASUS UX31xxx models?
I have UX31E, already upgraded the SSD via an adapter but I'm trying to understand the possible ways for upgrading the RAM.
Thanks in advance.
Update (01/30/2023)
Could you find any solutions for upgrading the soldered RAM?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@desideroali, On boards with soldered RAM, it’s only possible to “replace” with high level board work (micro soldering).
This is not a DIY task. It requires a lot of skill, appropriate tools / equipment, and a LOT of patience.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thank you.
And what is your suggestion for accomplishing this? Any suggestions for repairshops or compatible hardware?
And even if this is done for UX31E, is the motherboard compatible with 8GB RAM?
さんによる
@desideroali A reputable micro soldering shop should be able to do it, but be prepared to pay a fair bit for the job.
As for compatibility, all information I’ve found on the UX31E says it’s a maximum of 4GB. It’s not to say it isn’t possible, but unlikely.
さんによる
コメントを追加
回答を追加する
desideroali さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 13
過去 30 日: 36
今までの合計 631
