メインコンテンツにスキップ
Microsoft Corporationが設計したXbox One Sは、2016年8月に発売されました。Xbox One Sは、Xbox Oneを再設計した製品です。
433回答 すべてを表示
How to fix the water damage?
I spilled sweet tea in the fan part of my xbox. I had it on for 2 hours (after the tea was wiped up) and it worked perfectly fine until it shut off and wouldn't turn back on. I had it turned upside down and unplugged and nothing helped. UNTIL today I used an air compressor to shoot bursts of air into the fan and it turned on. BUT after I turned it off it wouldn't come back on.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
XboxUser Corrosion finally killed it. Time to try to resurrect it. First start taking it apart (STOP using it, you are just killing it faster;-)
Disassemble your Xbox by using [these guides] . After you disassembled your Xbox clean all the boards, board connectors and cable ends with +90% isopropyl alcohol. Follow this guide, and even so it was written for an iPhone, all the points are still pertinent to your console as well. While you clean your board, check for any obvious damage, like burned or missing components etc. Check your boards closely for corrosion damage. Post pictures of those boards with your QUESTION. That way we can see what you see. Use this guide to add images to your QUESTION iFixitでの質問に画像を追加する方法 Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. You also want to remove the fan and heatsink and replace the thermal paste. Once all this is done, reassemble your console and then reevaluate. Until it is cleaned, everything will only be a guess. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
iPhoneの画像
ガイド
iPhoneの水濡れ・水没ダメージからの復旧方法
難易度:
難しい
1 - 2 hours
iFixitの画像
ガイド
難易度:
とても簡単
2 - 5 minutes
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
XboxUser さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 29
