メインコンテンツにスキップ
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
107回答 すべてを表示
Why is my coimputer spontaneously turning off while playing games?
Hello
Two weeks ago I brought a brand new computer and after a while of using it, i notice something very strange. My computer spontaneously turned off while playing. What was strange about it that computer shutdown was in some sort of phases .
1. My monitores went black but i still was hearing sounds from game and discord in my headphones.
2. After like 2-3 seconds my friends couldnt hear me via discord but i still heard them (no sound from the game).
3. After 7-10 second computer shut down a system, but not himself (fans was still going) and rebuting a Windows 10.
And it happends like 2 time a week.
Does anyone know what could be the problem here? It happend whlie playing those games:
Escape From Tarkov - FullScreen/Bordeless,
Unturned - FullScreen
League of Legends - FullScreen.
I thougt meaby processor was overheating so i cup it at 180W and he never went up more then 77C. But PC Still turned off.
Im not a hardcore player and im mainly using my pc for blender and photoshop and it never happend while using those programs.
Here are spec of PC
- Intel Core i9-13900KF
- Motherboard MSI PRO Z690-A DDR4
- G.Skill Ripjaws V, DDR4, 32 GB, 4000MHz, CL18
- Samsung 990 PRO 1 TB M.2
- RTX 4070Ti
- Water Cooling MSI MAG Core Liquid 360R V2 3x120mm
- be quiet! Straight Power 11 1000W 80 Plus Gold
- Palit GeForce RTX 4070 Ti GameRock Classic
- Windows 10 Enterprise - 22H2 Update
I really would like to get some help, beacuse i dont know what to do.
Sincerely
Paul
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
Did you overclock/undervolt it?
さんによる
No, only set max WATTs in Bios, max 180W for the processor.
さんによる
コメントを追加
2件の回答
最も参考になった回答
Hi Krzemin, a low-spec related crash seems unlikely to me (btw congrats on ur impressive rig), on paper your PSU should be plenty capable of pushing this high-end build, cpu+GPU combined power consumption should be around 530W (253+277), full system will probably reach 650-700w (I take it the double "RTX 4070Ti"s on ur list is a typo, however if you do have a SLI setup it may infact be too much for that psu to handle when you start pushing the system to the limit).
If you already made sure the components' temperatures look good, I suggest you move on to checking the system's log, here's an how-to, just open Event viewer and browse 'Windows logs' > 'System' and look out for recent error reports. This way we can try to figure out if the crash is due to software bugs, bad drivers, hardware failures etc.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
My computer just crashed again and I've found out in windows logs (idk, how it translates from Polish to English version), there is an Error
- Volmgr 161 and 2 seconds later Kernel-Power
If you need more specified things, please let me know.
さんによる
@Krzemin Just wondering, is this a clean install of W10, or an update? However, first and foremost I'd backup any important data you have on there, then move on to troubleshooting: here you have 5 possible fixes for the kernel-power error: https://www.makeuseof.com/tag/fix-window...
Namely, in short:
- update windows (the error may also have been triggered by a recent upgrade, in this case a rollback could fix this)
- Disable fast startup
- Reseat RAM and GPU (also run a memtest while you're at it)
- use diagnostic tools like CHKDSK, SFC and DISM
- check your PSU health
さんによる
Other things that might work:
- update your audio device driver, disable duplicate device drivers, modify power settings (ref. https://answers.microsoft.com/en-us/wind...)
- update the mobo's chipset driver and firmware (ref. https://www.windowsphoneinfo.com/threads...)
- update GPU driver
- disable automatic restart from Advanced settings, so you can see the error message clearly on screen when occurs
さんによる
コメントを追加
Try gameing if you have on different GPU or only on CPU if it has onboard gpu. see if it crashes . if not its a PSU problem. Also it can be from win10 so I suggest trying different OS (like 7 or 8 maybe). Can also be from drivers. Bios setting has CPU-shootdown temp somewhere so it may also be a board design fault , not enough current on MB(somewhere). it may also be a GPU problem, was it new? (try older drivers crimson or anything the oldest you can find working with the GPU).
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Krzemin (Krzemin02) さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 24
今までの合計 99
