Why does my vacuum only stay on for a second and turns off
Why does my vacuum only stay on for a second at a time
@bearman63 sounds like a battery issue. Replace that and then re-evaluate. If nothing else it will give you a known-well starting point for further troublshooting Shark Cordless Pet Perfect Battery Replacement and it can be purchased from here
このアンサーは役に立ちましたか?
I had the same issue. The battery was fully charged (~15.5 volts) and I checked it's capacity by straight wiring it to the motor, which ran fine. The problem was apparently on the circuit board.
My solution:
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 31
今までの合計 247
