メインコンテンツにスキップ
The Droid Razr is an Android-based, 4G LTE-capable smartphone designed by Motorola.
60回答 すべてを表示
Removing back cover of the Razr
When removing the back cover or the Droid Razr, is there anything other can clips fastening the cover to the rest of the phone? e.g., is there adhesive or anything else?
I ask so that I can be sure to have the right parts for replacement and so that I can judge the risk in removing the back.
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント
There is definitely adhesive backing to this. You can try and get back off but you will risk breaking the part where volume and power buttons are bc of the strain. Yes there is probably a way to get off, but higher risk of breaking back of device. Buy a Galaxy is you want expandable memory and ability to remove the back. The Droid backing however is designed to protect phone better from drops.
さんによる
コメントを追加
3件の回答
ベストアンサー
Hey Josh,
The back cover of the RAZR is secured pretty tightly; however, it contains no adhesive or anything else. It is simply secured rather well with clips and well-fitting parts. With a spudger, a plastic opening tool, and a little concentration, the back cover should come off just fine. It is also built pretty well, so the risk of you damaging the device is rather low.
Hope this helps! Good luck!
Spudgerの画像
製品
Spudger
$3.99
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
Jake is right. This was one of the toughest parts of the teardown. We think it has to do with that Kevlar back being held in tension.
さんによる
Thank you for the quick response. Another reason why www.ifixit.com is the first place I look to for electronic tear downs and repair advice.
さんによる
Glad we could help, and we appreciate your gratitude! Have fun with your repairs!
さんによる
コメントを追加
Hi all
I want to recommend every one that want to do any repair work to take photos and notes during the repair process.
http://smpstroubleshooting.com/
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
We already did all of that for you. We have a complete set of guides for the Droid RAZR.
さんによる
コメントを追加
i had taken off the back and it did not brake on the other hand though DO NOT REMOVE THE BATTERY it contains an orange ribbon and if that brakes it voids the warrenty. you will have to pay full price for a new phone but DO NOT REMOVE THE BATTERY just simply hold the power button + hold the volume up button at the same time
hope this helps
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
to reset the phone
さんによる
コメントを追加
回答を追加する
Josh さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 6
今までの合計 47,352
