メインコンテンツにスキップ
Xbox Series Sは、マイクロソフトの最新のスモールフォームファクタ、デジタル専用ゲーム機です。Xbox Series Sは、よりパワフルなXbox Series Xと共に2020年11月10日に発売されました。
20回答 すべてを表示
Missing diodes near the HDMI port. Can anyone ID them?
I have some missing (what looks like) diodes under the HDMI port.
They are small, black rectangles. There is a line on them like a diode. There is a small marking on them that looks like a "7"
There are 8 of them in total on the board. They are on pin 1, 3, 4, 6, 7, 9, 10 and 12.
I am missing the ones on 1, 3, 7, and 9, although I think all 8 of them are the same.
They are marked "EG###" on the silkscreen.
Can someone ID?
EDIT: I found the schematics and they show part number M1015860-001 but Googling the part number returns nothing useful.
I would rather not have to buy a whole broken motherboard to salvage these parts if I can help it.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
3 件のコメント
Are you certain there are supposed to be diodes there in the first place? I've seen perfectly working motherboards with seemingly missing components.
さんによる
Yes, these are TVS (Transient Voltage Supression) avalanche diodes that are for clamping incoming ESD surges from the HDMI port, dumping excess current to ground in the event of an ESD hitting the HDMI port. They are protection diodes.
さんによる
Hi, have you fix it? I have the same issue and not able to find spares.
さんによる
コメントを追加
3件の回答
最も参考になった回答
Matt by the symbol you know that those are TVS diodes. In this case they are used as HDMI filter ESD TVS diodes. Problem is that there is nothing with the number you listed. Which is not a surprise since this may be a single manufacturer that made some deal with microsoft. The Xbox One X used different packages for those diodes but those should essentially have the same values.
Working Voltage: 5 V
Termination Style: SMD/SMT
Clamping Voltage: 8.4 V
Vesd – Voltage ESD Contact: 12 kV
Vesd – Voltage ESD Air Gap: 25 kV
Cd – Diode Capacitance: 0.5 pF
Ipp – Peak Pulse Current: 4 A
You could try Mouser.com or Digikey.com and see if you can find them. You can also contact both of those via email. Their customer service department is usually pretty helpful. Or you could get a board that has failed, other than the HDMI circuit, and use it to harvest those diodes. If nothing else, check on here and see if they can help you.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Thanks oldturkey03 I have one here with the same issue and this info was invaluable. Cheers!
さんによる
コメントを追加
These are not an exact match but they are the closest i could find. In theory they should work.
https://www.mouser.com/ProductDetail/KYO...
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
This one is a bit large for this application, but with some creative installation it could work.
さんによる
is it matter if they are bidirectional or unidirectional ?
さんによる
S should be the same because they are filter diods for 4k resolution
さんによる
コメントを追加
ESD Suppressor TVS Diode For Xbox Series X Board EG695 EG689 EG701
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Matt さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 17
過去 30 日: 62
今までの合計 2,132
