メインコンテンツにスキップ
Microsoft Corporationが設計したXbox One Sは、2016年8月に発売されました。Xbox One Sは、Xbox Oneを再設計した製品です。
20回答 すべてを表示
No sign of life.
Xbox one S has no sign off life. Have tried to change power supply and used different leads and sockets etc. any suggestions?
Update (01/25/2023)
I forgot to say, it started smoking plugged in, on replacing the power supply the smoke came back
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
8 件のコメント
Frankie Vaughan smoking electronics is never a good sign. You replaced the power supply and it smoked again? Can you let us know where or what smoked? Post some good pictures of your PSU and your main board etc. with your QUESTION. That way we can see what you see. IF a new PSU went up in smoke, something is shortening it out and that would most likely come from the main board. iFixitでの質問に画像を追加する方法
さんによる
To be fair, I didn’t even look. I ran up to grab my phone. As I came down it was smoking😬. Just quickly unplugged it as I was working in a wooden outer building😂. I have stripped the disc drive, power supply, hard drive and fan and can’t see any signs of damage. Must have been the underside. To be fair I think I’m going to just give up as that was too close and I don’t have much experience with micro soldering. Thanks though!
さんによる
@Frankie Vaughan you sure? Don't even want to check? :-) Sounds like you already have it mostly apart. All it takes for now are a couple of good pictures. Remember: REPAIR IS WAR ON ENTROPY
さんによる
@oldturkey03 probably going to be a fet on the 12v rail, but why anyone would ask on here to get advice and the give up is mind freezer
さんによる
@tech_ni that would make sense. Do you know if that is a common thing with the One S? Checking it and even replacing it should not be to bad and probably cheaper than a new Xbox :-)
How is winter going for you? You all doing okay?
さんによる
3件以上のコメントを表示
コメントを追加
3件の回答
ベストアンサー
You likely have a big cooling issue. I would suggest replacing the heatsink if none of your boards are severely damaged.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
if it was a cooling issue it would still show signs off life
さんによる
@russellrepairs but where would the smoke be coming from?
さんによる
@oldturkey03 I suspect that the cooling issue caused an overheated power supply
さんによる
コメントを追加
最も参考になった回答
is there any signs of burning in this area
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
@tech_ni looks clean to me 🤣
さんによる
@strongbow maybe slight corrosion around the retimer lol
さんによる
@strongbow @tech_ni the reason why it can't work is because there are no lines between the components.
さんによる
@oldturkey03 I didn't notice that lol
さんによる
コメントを追加
It could be an over heated system the chip might be fried 😬 I hope now but get it checked out
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Frankie Vaughan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 10
今までの合計 235
