Damaged SD card reader
Hi All
What is the correct part I need to get in order to replace a damaged micro SD card reader for the switch OLED ? It is the daughter board ?
Hello, sorry for the late response, if you want to replace the MicroSD card slot you will need to replace the black and orange daughter board, a guide for which can be found at Nintendo Switch OLEDモデル ゲームカードリーダーのドーターボードの交換. Best of luck with your repair!
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 3
過去 30 日: 30
今までの合計 169
