メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
start iPhone 5 with broken glas
I have moved to a newer iphone. But I have some SMS and photos which have not been backed up on Icloud. Is there any way to start the phone without using the front display so that I can download SMS and photos from the memory in the phone?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
最も参考になった回答
try 3utools (it's free). if you can get the phone to boot, while connected to your pc, you can pull individual stuff (pictures, videos, etc) directly out of the phone. it can also do whole phone backups (not sure if the backups can be read/restored by itunes)
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Just press the power button and let it boot, then use itunes to make a backup of the iPhone and flash it on your iPhone.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I started Itunes but it requested that the lock code for the phone is entered. But since the display is damaged and does not work I cannot unlock the phone. Is it possible to get around this problem?
さんによる
@laxen sadly, that's the only way I know..
さんによる
コメントを追加
@laxen you can only do that if you don't have any kind of screen lock. If your phone requires you to enter a passcode, you cannot do that without the display.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
very true. and also if the phone wants you to trust the computer.
さんによる
@beekerc that's right. I forgot about that Trust issue :-) Good point
さんによる
コメントを追加
Well actually there may be a way - go get a lightning to USB adapter and connect any generic USB keyboard to it - not sure it still works, but well worth a try.
If possible - try connecting that keyboard to a working iPhone and test and if it works - wait for your phone to boot up, blindly enter your passcode and you should be good 👍
P.S.: and actually even without a display you can see what you phone would show if you connect your iPhone to a Mac and run QuickTime to capture iPhone’s screen. Here’s how:
https://support.apple.com/en-gb/guide/qu...
It may be necessary that you have connected your phone to this Mac before and made your iPhone trust this computer- keep that in mind
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
i didn't even know that was possible.
さんによる
コメントを追加
回答を追加する
Tomas Persson さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 50
