Hi Alfie,
Boy, I tell ya, I had no luck whatsoever finding any information about your laptop, so I can't help with any clues about where the CMOS battery may be located. There were a few threads that talked about how some models of Toshiba Satellites don't have CMOS batteries and instead rely on power from the main battery, which means you end up having to reset the CMOS memory every time you remove the battery. However, none of that was specific to your laptop, so it may not apply.
On the other hand, I did find one seller on Amazon selling batteries that are supposed to work in your laptop. Here's a picture of what it's supposed to look like.
And a link to the Amazon page so you can take a look for yourself.
Replacement CMOS Battery For Toshiba B450 B451 B452 B550 B551 B552 L35 L36 L40 L41 L42 L45 L46 L47 BACKUP Reserve Button Cell Batteries 3 Pins 2 Wires: Amazon.co.uk: Computers & Accessories
I'd start by removing the bottom cover; hopefully they didn't make it ridiculously difficult to replace the battery by doing something stupid like putting it under the motherboard. Look for that little white connector on the end of the wire in the picture; I'd start looking in the corners by the hinges. If you find it, follow the wires to the battery pack; it may be under a cover, glued to the case or just taped down.
That's about all I can come up with for you; maybe someone else will have better luck finding any kind of repair or teardown guides or videos for you. Good luck and let us know what you find; it may help someone else in the future.
P.S. If you do figure out how to replace the CMOS battery, you might want to consider taking pictures and creating a guide for the poor saps who have that same laptop and no instructions either. It's really not hard to do and there's always people here who'll help you through it if you run into problems.
1件のコメント
What is the exact model number of your laptop?
mike さんによる
