メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The Samsung Galaxy A52 Is a Mid-Tier phone released by Samsung on March 17, 2021.
My toch is not working
Hi my name is alex and i have a samsung A52 and im a fix it my self type of a person and few days a aho my screen had this line appers when ever i press my screen little bit hard on the bottom and my phone was working great it didn't have any cracks on the screen but the ribbon cable was weird and i tooked to a phone repair shop and it said the ribbon cable is bit weird and i disided to clean the ribbon cable with a cleaning alcohol and it was working great and now the toch wont work what shoud i do
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi Alex,
That is a bit odd that your LCD is working fine but your digitizer isn't. On things like iPhones, they have separate connectors for the two, but yours is a combined connector that has both functions on it, so if it's a connector issue it's unusual for only one of those functions to be affected.
That being said, however, there's really not much else to check or fix. So at this point your best option is to open up the phone again and unplug the display connector. Of course you disconnected the battery first when you did your repair, right? Check both sides of the display connector with a magnifying glass for any debris or contaminants and also look for bent or broken pins. A bent pin can frequently be straightened with fine tip tweezers. While you have it open, check as much of the flex cable as you can for any damage.
Once you're done checking, plug the display back in, being careful to make sure it's fully seated in the connector; long plugs like that can flex and end up with one end not fully seated, so be sure it's all the way in. Reconnect the battery and see if the touch is working yet. If not, you may have to remove the screen again to examine the display's flex cable.
That's really about all you can do. If nothing has worked up to this point, then you may be looking at having to replace the screen to get it working again.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thank you for your answer last night i did open my phone agian and looked at the flrx cable and heated it up with a heat gun to the and the toch came back but the white line is back and i was thinking to heat up the display connector
さんによる
コメントを追加
回答を追加する
Alex dja さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 42
今までの合計 887
