メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
Can I install an iPhone 5 Battery in an iPhone 5S?
I was just given an old iPhone 5s that is splitting at the seems. Clearly it has a battery that is going bad. But the phone still power up and works.
Unrelated to that, I have an old, unused iPhone 5 battery sitting on my desk for like a year now. I bought it for a different phone but that phone died before I got around to installing it.
Can I put the 5 battery in the 5S?
Looking at photos, they look physically identical.
Looking at specs, it looks like the 5 battery has a bit less capacity, but thats no big deal.
What do you think, will it work? I wouldn't be using it as a phone, probably just as a clock or something. Maybe a remote. I can get SOME use out of it I'm sure.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi
Unfortunately you can’t install a iPhone 5 battery in a 5S due to the sockets and connector being different
iPhone 5 has 4 gold contacts
iPhone 5S has 3 gold contacts so the battery won’t be compatible with both
If are very electronics savvy you could probably take the BMS and cable and put them on the battery you wanted assuming that the voltages are the same
Hopefully this helps
Any questions please ask
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
The connectors looked the same from the images I saw, do you have closeup images of the two so i can see the actual difference between them?
Also the voltages ARE the same between them.
さんによる
@John M
Il get some close up photos and add them to their answer
さんによる
@John M
Iv added some images for you:-)
さんによる
コメントを追加
回答を追加する
John M さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 4
今までの合計 42
