water spilled in console
a small enough of water was spilled in my console. The system turn on but when I try to play a game the system turns off
Hi
The best thing you can do is take the whole device apart and assess the damages
The sooner the better
Here’s a guide for disassembling the console
It might be worth taking the heatsink if you can’t find damage but be careful as Liquid Metal could spill and WILL cause damage
If any corrosion is found isopropyl alcohol is a good cleaner for it
Also it helps if you don’t turn the device on
Hopefully this helps
Any questions please ask
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 788
